Yo ladies.
Killer of a Day. Brisbane - Lismore - Brisbane - Cairns...
Tomorrow is Cairns - Townsville. There for 2 Days, then back home.
Thursday - Brisbane - Sydney and return back home Monday night.
All in the name of getting paid...
^^^ truth
Hey, how did you go with cuntstable whats-his-name?
He hasn't been back at my place since, and haven't heard anything, so am hoping that's the end of the matter.
Ok so i went to my local tyre shop this arvo. Question to y'all does anyone want new rims?
I can get 2 sets:
Work Meister S1
18x8 +35 / 18x10 +22
Polish Silver Finish 2 peice
Offers around $2500-$3000
Work Emotion XD9
18x9 +30 / 18x10 +22
Magnesium Finish
Offers around $1500 - $2000
They are brand new in box never had tyres fitted, all 5x114.3 and all legit. If you want them PM me and i'll put you in touch with them
John's day at school:
Got there early and there were a couple of people already waiting, they were slaves, but they seemed aiight. Not the kind of slave to boost your car, but not the kind you'd trust around your wives or daughters either.
Then slowly more people arrived including one sandwich maker that's as wide as all outside.
Then some dude turned up to show us through the buildings etc. While he was talking the bus of wayward youths turned up. Flat cappers, skinny jeaners, lip ringers - that kind.
Turns out it was two groups - one for automotive, and one for construction... strangely the majority of the herpaderps went to construction...
So then my class breaks down thusly:
15 people
1 fat fucker who already think he knows everything because he has already done 3 tafe courses...
4 slaves (2 decent ones I met to start with, and two coon slaves who just laugh and carry on like tools the whole time.)
1 half slave 15 year old fat fucker who walks at roughly the same pace as erosion took to form the grand canyon, until he gets to a flight of stairs. Then he simply lets gravity so all the work and nearly killed everyone else on the stairs twice...
1 other 15 year old who had no concept of time and comes back late from every break
1 mobile sandwich unit who doesn't understand the simple instruction "no food or drink in the classroom... and ate the ENTIRE day.
4 stoners, one of whom can't lift his feet when he walks and it sounds like he's dragging concrete blocks along the ground. Lazy cunt. Major attitude problem too. Cracks the shits every time they do a roll call as though he shouldn't have to be asked more than once in his entire life.
2 nerdy looking gits
And me
Out of those 15 people. 5 were there on time. The other ten GOT LOST on the way there. Catching the wrong train/bus, Not being able to find Bracken Ridge, etc. 3 of them had to leave early to go and buy safety gear that they should have already had and have had more than a week to get it all. One of the people who got lost actually was so stupid that they drove around looking for it until they ran out of fuel...
Martin - turns out the guy with the Alfa wasn't the teacher, just the guy ushering us into the building and stuff.
    • I'll get one of these also just for giggles
    • I bought 6 new spark plugs to compare readings. They will be here tomorrow and ill see if meter is far off if it all. I know one is at least reading 0 so its best replace all anyway if one is bad, from experience. I still have to test the harness just to be sure its not a double issue and I waste my time haha-the old plugs are iridium I always thought those lasted more than 50,000 km.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
