He hasn't been back at my place since, and haven't heard anything, so am hoping that's the end of the matter.
thats the going rate. I will have one here tomorrow night if you do no good there. Mint. (hate that word)
My guess would be a light automotive course. Seems like every new apprentice we get these days is a knuckle dragger too lazy to do a decent days work
Ok so i went to my local tyre shop this arvo. Question to y'all does anyone want new rims?
I can get 2 sets:
Work Meister S1
18x8 +35 / 18x10 +22
Polish Silver Finish 2 peice
Offers around $2500-$3000
Work Emotion XD9
18x9 +30 / 18x10 +22
Magnesium Finish
Offers around $1500 - $2000
They are brand new in box never had tyres fitted, all 5x114.3 and all legit. If you want them PM me and i'll put you in touch with them
Far out those XD9's are cheap. Tempting.
make an offer miso, he wants them gone.
If i had a complete 5 stud conversion ready for my 31 i would be buying those Meisters.
Meisters do kick ass >_<
What is it your doing at tafe..
see below
got it in one >_<
This is a new one :S
fitted 20mm spacers (very good quality ones from japan) and long wheel studs for the spacers to eliminate the bolt on studs.
So you are using bolt-on spacers as slip-ons?
they are bolt on, i have removed the bolt on bolts to allow the long wheel studs to go through instead, plus i heard that is a lot safer
lol thats not safer at all
i got told it was safer by a wheel shop to run spacers like this, so there is less stress on the indside wheel studs on the spacers. they advised me that they wont snap like this.
The wheel shop in question must be a bunch of incompetent twats.
Final quote was me >_<
quoting is where its at col.....
although i hear its better to only run 2 studs with spacers to reduce the stress...
geoff you know you want to buy sweet rims...
Sweet rims indeed. But no, not interested today, sorry. I'm happy with the ones I've got (not got the spare cash and theres more important things to do to mine first anyhow).
John's day at school
I went to an Epson training day a few weeks ago which pretty much entailed of me doing everything really really quickly so I could get the f**k out of there before someone would ask me where I work and then proceed to tell me how much better their job is than mine for the eleventy millionth time.
On a side note, checked all the hoses tonight on the skyrice, I didn't have enough light but I could hear a slight psssss sound, so I'm going to replace the hoses from the boost controller + bov.
Oh, and John if the series 1 afm pwnd had will work on a series 2, I'll come and pick it up from you on friday or saturday if that's cool.
Tell Andrew that if he wants someone who actually wants to do the work, and actually wants to learn, that I'll still come work for him. The course is done in 4 weeks :(
PSSSSSSS noises aren't good in.... See if you can get a leak tester :D
As far as I'm aware - series 1 is green, series 2 is pink. I only say this because when I was looking for one I got told a green label from a series 1 25 would work on my 20. *shrug* Best bet is if Miso can bring it along, I'll just grab it and we'll try and see what happens.
Jason has some spare coil packs for a 25 now that I think of it. Maybe he'll let you borrow them to trouble shoot further if the AFM isn't the problem. You'll have to ask reallll nice like though :(
Noel, your car is Mint.
@John: Lol
Alvin ROOLZ
I can do better in the wheel department.
Howbout a set of brand new nismo lmgt4's in 9.5x18. +30 offset with new tyres for 3500....or...Da bomb...Volk GTC's in black with chrome lip gtr offset +12 9x18 with feddy semis 50% tread mint for 3 kay.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
