I'm inclined to agree... But, being a researcher, I'd like to see more to be sure :D
Of green, or of *. take your pick. just moar.
Edited by GTTG
Morning! Ice cream last night hit the spot, I had been bored at home all day, needed dessert and wanted to drive my car, all my problems solved in one hit!
See you guys next week?
Probably not, next week we are starting our plan to get the gym as often as we should again!
Oh and i didnt manage a 'skid to leave' as requested, I forgot to switch the ATTESSA off :D
Hahaha
Noel gave it a good crack :P
ha ha he is good like that! At least I made the most noise :D One of the fisrt couple of things he came to was a ribbetts dinner, upon leaving he pulled a rather large skid....then remembered that there was a police station across the road! lol
Good mornging good sir's...
How was teh ikes Cream?
Please enlighten the non-down-with-teh-lingo-due-to-insider-jokes/trading.... of said green and *
:D
Touche. More data required.
Ahahahahaha. I like your thinking!
Ice cream solves all :D
ha ha he is good like that! At least I made the most noise :) One of the fisrt couple of things he came to was a ribbetts dinner, upon leaving he pulled a rather large skid....then remembered that there was a police station across the road! lol
Your car sounds pure porn btw.
:P
Green > * thats all you need to know.
It does sound good, I love it, now its just a matter of avoiding defect butt rapings for as long as possible!
Doing it wrong. Needs more Baskins attendance.
Will be there next time. Had a bitch of a week at work, the skyline is still off the road, and didn't really feel like showing up in a festiva or a golf.
Saw your ride this mornin. Hope it all goes well bud. :banana:
The almighty, the invincible, the indefectable ALVIN would rape it hell west of sideways. :down::banana:
at being being purple? yes in that case it would!
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
