I'm inclined to agree... But, being a researcher, I'd like to see more to be sure :D
Of green, or of *. take your pick. just moar.
Edited by GTTG
Morning! Ice cream last night hit the spot, I had been bored at home all day, needed dessert and wanted to drive my car, all my problems solved in one hit!
See you guys next week?
Probably not, next week we are starting our plan to get the gym as often as we should again!
Oh and i didnt manage a 'skid to leave' as requested, I forgot to switch the ATTESSA off :D
Hahaha
Noel gave it a good crack :P
ha ha he is good like that! At least I made the most noise :D One of the fisrt couple of things he came to was a ribbetts dinner, upon leaving he pulled a rather large skid....then remembered that there was a police station across the road! lol
Good mornging good sir's...
How was teh ikes Cream?
Please enlighten the non-down-with-teh-lingo-due-to-insider-jokes/trading.... of said green and *
:D
Touche. More data required.
Ahahahahaha. I like your thinking!
Ice cream solves all :D
ha ha he is good like that! At least I made the most noise :) One of the fisrt couple of things he came to was a ribbetts dinner, upon leaving he pulled a rather large skid....then remembered that there was a police station across the road! lol
Your car sounds pure porn btw.
:P
Green > * thats all you need to know.
It does sound good, I love it, now its just a matter of avoiding defect butt rapings for as long as possible!
Doing it wrong. Needs more Baskins attendance.
Will be there next time. Had a bitch of a week at work, the skyline is still off the road, and didn't really feel like showing up in a festiva or a golf.
Saw your ride this mornin. Hope it all goes well bud. :banana:
The almighty, the invincible, the indefectable ALVIN would rape it hell west of sideways. :down::banana:
at being being purple? yes in that case it would!
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
