Saw your ride this mornin. Hope it all goes well bud. :banana:
Surprised Dan didn't just push it off a cliff and claim it was stolen
It's all strapped up and waiting to be tuned at EFI. Spoke to Dan a few minutes ago.
Will be interesting to see what she makes! What are you hoping for?
you're missing a bit...
you're on the right track
Green
Pink
On one hand I agree.
On the other hand though, things will only get better once the green is removed :starwars:
Standard bottom end, so it would be nice to see 300rwkw, but any improvement on my current 220rwkw will be good.
should see that comfortably at around 15 -16 psi!
Partial credit??
Green
Pink
haha!! So once green is removed it becomes = pink > *
Should be awesome!
Isola was that you on the side of Albany Creek Rd last night with the bonnet up? I was following someone so I couldn't pull over.
That was me. My AFM has been a bitch lately. I cleaned it and the plug so many times and I just couldn't work out what the problem was!
Got it sorted now though, it was the secondary connection on the strut tower (which I didn't realise it had!!) that was full of sand and dust and shit. Pulled over and flushed it with WD40. Was that you going past in the silver 33 giving a big turbo vent salute? :happy:
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
