you both accidently a rim!
So guessing your rolling on GTP's again? i seem to remember bending one of them, and then fixing it with a hammer
so, tristan and martin, what happened?
I totally hit a pothole, yeah :P
martin, yours might even be salvegable
Yup just got a quote from dupulo, about $165 all up to fix it including freight both ways.
Proof that jap rims > cheapo chinese rims
Wow good effort guys!!
That's what she said
Martin = ???
Martin = win
Sup mangs
My birthday this weekend...... you carnts gonna come out for a beer friday or saturday night?
Sup mangs
I'm still hurt that you stole the love of my life :)
...If I don't end up flying to radelaide, I'll try and come out on one of the nights for beers. Where you gonna be?
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
