call me picky... but the chick in #2 has some muffin-top going on....
Tits like that come with hips like that, fact of life, and its not a bad thing!
f*ck. Still 45 mins to go :thumbsup:
burger challenge sat? Maybe. Lakeside is sunday but I won't be doing the deathburger anyway. However, Sometime on Saturday Scott and/or Dan has to detail my car :P so if thats not done by dinner time (and colin has dinner mid afternoon) then it could be a problem.
Yeah I don't really wanna try the deathburger the day before lakeside. could make it difficult to enjoy jap nats while shitting through the eye of a needle.
Off the Wall diner in Wellington point makes the worlds hottest burger. if u finish it without drinking anything you get your name on the wall. You have to sign a waiver before you eat it and all sorts of cool shit. Causes hallucinations and epic pants shitting. Oh and it hurts like hell. Wanna try it?
is it too late to register for lakeside this weekend?
F-Yes! I'm a curry so it couldn't be that hot. =D
Just for reference. The sauce they put on the burger is 500 times hotter than a jalepeno chile. It also has 10 of those and a teaspoon of chile powder in the pattie. There is a tablespoon of the sauce on there aswell.
Colon, you give me no credit.
You should taste my curries. =D
Also, if you were kind enough to pick me up, I'd gladly take it on. =D
QFT, she's bang'n hot.
Colin, our downhill rides aren't completely crazy, the bike im currently on is a little too small to really push hard on but its good fun and the pace is alright. New bike buildup will be better for harder runs, im currently limited to how big my tyres can be on the current one cause of the frame width.
Martin the disc's you got at the moment will be ok for what we do, when i first started the norco was running V brakes all around which was great until you got dirt, or mud, or water into them then you couldn't stop without using your feet.
Today was a very long day for me, but made even funnier by one of the mechanic's failed attempt to rebuild an engine, no spark on cylinder 5 hahah
Ohhhhhhh I heard about that last year and have wanted to try it ever since!
I'm ashamed to say that lately though I haven't been hitting hot curries much. I can eat a medium one at the moment but that's about as hot as I can get. Go back about a year or so and I was eating shit-hot vindaloos for breakfast without dramas. f**k I love my dads curries.
I'm off camping at a hippy rave out west this weekend (haha!) but I'd be keen if it's next weekend though? Or is it already set in stone for this weekend?
i dont think ill be able to this weekend so im keen for a reshuffle. if not ill got out n watch miso try it but wont be trying it myself. we can always go back again the burgers are pretty good there.
Dear Scott,
Can you please detail my car either friday night or saturday?
Pretty please :)
I'll come to you if you like, or you can come here, whatever you prefer
Love
McFly
i am easy on the burger date. a re-shuffle doesn't bother me, as it gives me some time to eat some hot food and hopefully get in practice for the burger.
in all honesty, i don't eat a lot of hot food, so am aware that i will fail miserably, but still want to give it a shot.
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
