What do you think is going to happen when you run at a car that is driving towards you? Stupid kid....
I can't believe the attitude everyone is taking towards this poor kid. Did nobody else see how those reckless hateful jews just ran him down for no reason? :D
Morning Mangs,
Weekend was wet.
End transmission.
It isn't raining that bad on the coast. Looks like brissy is copping most of it. Although we have some awesome wind blowing through atm.
I was in the falcon this morning, just set my sail and I was away!
I thought about taking my XF, but it does not stop in the wet :D
It is absolutely pissing down right now.
So fkn tired of rain! I am REALLY appreciating having AWD though.
Pffft, I did not desire AWD once this morning. Just a little more ground clearance...
I didnt desire AWD till i had it either, full throttle in the wet FTW
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
