Yeah another negative. But it has been fairly disappointing there for the past 3 or 4 weeks now. With employees anyway.
I am dissapoint, I was all keen for hot youngness, but no!
sup Ravbat. Ice cream was average. Shitty milkshake and retarded employees. But shit happens. Hating work also.
dont forget that they were in no way hot!
Finally time for northside meet spot instead??
Hey mangs. Was stuck out working again, hence another no show last night.
Some pics from the southside meet. Night was spent laughing at the flat cappers.
Edited by SABBAi
Yo fellows,
Has anyone got a RB 20 coil pack loom or one that's interchangeable?
or know of someone that can replace the clips on the end?
fuck your face
Yo fellows,
Martin has one. I know this because I stole it, and it's at my house.
I need a coil pack loom (and coil packs) that more or less work well enough to run a car...
Other than that, I'm not fussed. Would be nice if John came and undid all the damage he's done though :ermm:
Edited by Smity42
Other than that, I'm not fussed. Would be nice if John came and undid all the damage he's done though :)
Oh :ermm:
okay next offer. ;)
You home tonight, Mang? Lyss is going to Zumba at 7, so I could come up and fix it if you want.
Zumba!
There's a BnR in albany creek in front of the coles, I'm not sure if it's open late thursdays though.
Yo fellows,
you can buy the ends new... repco can order them in or visit your local auto-elec...
Its a simple replacement, just takes a few minutes and careful hands...
Much easier to do when the loom is out of the car, just remove the coil pack piece and work on a table away from the car (help with back bending etc)...
You could take the loom to an auto-elec also to get them to replace the ends if you want...
If I remember correctly they were about $12-14 each
Tis open til 8pm Thursdays...
My neighbor owns it... I was there last night at close (hence how i know)...
A little uneccesary..... but always welcomed :ermm:
You like a f**k face?
Zumba!
I'll just keep hounding CH until they get their shit together.
P.S... could you teach me how to play guitar scales/solos/lead etc?
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
