always
hairy muff
i like the ribs i just ate at the petrie tavern... $25 worth...
best ribs ive ever eaten in my life... had to thank the chef, was super impressed...
hairy muff
Should have come said hello
I refuse to go to the petrie tavern... it screams dodgy :P
local also hey?
i thought the same thing, but the food was amazing for a pub/tavern...
heaps better than warner, lawnton & albany creek tav's... their pricing is also very reasonable for what you get...
i will be going again...
If thats the kind of loves that get dished up in here... Count me in
face sex?
local also hey?
Yeah I'm about a 5 min walk from the tavern. You around this area also?
I might have to actually check it out based on your recommendation
We're all relatively local (those of us that count)... Tavern night?
You home tonight, Mang? Lyss is going to Zumba at 7, so I could come up and fix it if you want.
Sorry mang, I didn't see this until too late.
I have no magnetiz'd that screw you dropped though, and vacuumed all the crap. I should be home the rest of today and also tomorrow morning.
Or you can just do it whenever.
Or you can just give me the bits and I'll put it back together. I've had a look and you haven't done much damage at all, I forgot how easy it is to do coil packs when there is no valley cover on :P
Or you can just give me the bits and I'll put it back together. I've had a look and you haven't done much damage at all, I forgot how easy it is to do coil packs when there is no valley cover on :laugh:
Busy this weekend, that's why I was asking about last night. I can come over after tafe one day if you want? Or I'll just give you the bits on Thursday. It's not much damage at all. 8 screws, one bolt and 6 clips I think was all that need to be done up again.
Yeah im in Warner...
The warner tavern is too upmarket now (in terms of pricing) their food is ok, but not worth what they charge...
So we've been going to PRMBC & the lawnton tavern lately... But found a shopper docket for buy 1 meal get one free @ petrie tav and thought "hey why not give it a go"...
So two main meals, an entree each & 4 or 5 drinks later $42... Happy days...
Then the ribs of my life... It was a very good night...
Yeah id be up for it... small crowd would work, not much dinning space in there...
The ribs are all ive thought about since Friday...
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
    • Any idea where I can get genuine MAF apart from used ones? I can't find any only for GTRs and unfortunately that price is not in my budget 🤣 I might gap my plugs down and put my splitfires in, they were only in for a year or so before I started the rebuild
