Kids did trick or treat in the street tonight and one house down the road had a sign up saying we don't do halloween. So we teepee'd the cars/house. Great success.
You do want them
I need more power, and new front brakes, decided to take the "fun" way to and from Lowood, over nebo/glorious i love EBC Redstuff, didn't get any fade at all.
that they are.
I got new front brakes already, i just need to paint them shiny blue and get new pads for them, R33 turbo calipers will be fine on the daily, leaves me able to get some brembo's for the project car.
fark this weekend flew by. Between being on call, being drunk and all the sport, the days just disappeared.
when I get home I will post a pic of a p plater crash on the m1 we saw on our way home from the coast on saturday. it was a solid effort.
Nothing at all :blink:
I vote we impose immediate Chapel Hill boycott. Even if it means we have to go to McDonalds this week.
I would agree with you, but it seems that won't actually bother him.
I vote we go and use the table and chairs but don't buy anything, unless the staffing situation has been rectified.
I can see that not working though as too many people with a conscience will end up buying something...
Nandos could work... Nandos where?
I hate car photos that are taken on stupid angles like this one:
How hard is it to line the camera up? Why do they take such stupid shots? It usually hurts my head to look at them.
The photographer couldn't figure out how to get the car angled for a photo?
Afternoon all! After starting my car up this weekend for the first time in 5-6 weeks....... I think I've fallen in love again :D
There is a Nandos at Kenmore near the maccas.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
