There is a Nandos at Kenmore near the maccas.
sounds good to me. that general area suits me well
once again, near st lucia coles is quiet good as well, as there is a fair bit of eye kandy walking around at that time too
hey the 11th (night) ive been called up to work up the coast :D
wont finish until about 9pm
cant do the petrie tav that night... any other night is fine by me?
wanta think about the night before maybe? the 10th?
Tuesdays are out, Col. The fags play sport. I'm fine with the Monday though if you, and they are.
Tuesdays don't work for Dan or I... Indoor.
...What about the Monday? (9th)
f**k thats weak as piss of them
QFT
I would agree with you, but it seems that won't actually bother him.
I vote we go and use the table and chairs but don't buy anything, unless the staffing situation has been rectified.
It'll bother him when the money we spend doesn't turn up. I just see no point in going back if he can't even reply to a message. I don't think it's a great idea to turn up and loiter... it might attract the defect squad.
Does the McDonalds near Nandos have a McCafe? I'm keen for a Thursday coffee. Noel, seeing as a few of us are going to be buying food there, I doubt very much if they'll care about you turning up with fish and chips or something. And if they do, too fucking bad.
If lots of people have a problem with Nandos however, speak up now so we can organise something. I don't want to be organising this shit at 6pm on Wednesday.
Edited by Isola
There is a Coldrock/ 7Eleven/Dominoes/Indian in Kenmore.. about 1 minute from Baskins
Old Cock and Homoblows are fail. 7 eleven charge epic fortunes for everything and Indian (or any non fast food place) is probably too tricky for people coming and going at random times.
