Plan A:
There is a Nandos at Kenmore near the maccas.
Plan B:
sounds good to me. that general area suits me well
once again, near st lucia coles is quiet good as well, as there is a fair bit of eye kandy walking around at that time too
Plan C:
There is a Coldrock/ 7Eleven/Dominoes/Indian in Kenmore.. about 1 minute from Baskins
Vote now or forever hold your peace. Single vote, A, B, or C. Results will be tallied to determine the final destination.
Legitimacy is doubted as website states it was never on maps, and that it was only known as Teneriffe since 1975 when it was actually called that since the 1860s. And that it's postcode is 4006. Australia Post lists a postcode of 4005. Too many alarm bells for me.
ABC Reference
City News Reference
Plan A:
Plan B:
Plan C:
I vote B :verymad:
is there any food stuffs near the st lucia thingy mabob? If so keen for that. I don't really care lol.
Me either. I just didn't know what was down near where Miso was taklin' 'bout. That's the only reason I voted A over B. C was never an option.
Morning mangs.
What an underwhelming response...
My preference is C... but I really couldnt care less if it is one of the other ones.
Looks like C is winning at the moment, any more votes?
Edited by Smity42
Hey guys.
So much bantering and lol's at Johns.
Prob wont be at the southside meeting tonight or the *to be determined* Thursday night meet. Looks like I'll be doing an overnighter in Rocky for work...Why do they always fall on Thursdays?
C it is then. If it's shit we can try option B next week.
Arright, sounds good to me.
Meet HERE at 7:30PM.
John, There looks to be at least two coffee shops there for you :verymad:
Anyone else coming to that southside meet tonight?
Negative, Boss is over from Perth looks like he's shouting dinner.
Hey guys.
Sucks to be you.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
