Godf**kingdamnit I hope this is sarcasm :D
It's not.
I'm sure Ravi already has genital warts :)
HEY!
You're probably right
But lately I've liked the idea of filling the entire space with some massive chrome bling dinner plate style thing....... so ridiculous....... so beautiful......... *sheds a tear*
Ravi, i love you to bits.
but...
ARE YOU SOME KIND OF f**kING RAGING HOMO?!
let me choose your wheels :D
Morning Mangs,
TFIF
Positives from last night:
Ice cream was better
Negatives:
Nowhere to park
Nowhere decent to sit
No JB
Store shuts too early
Colin ran me over :D
Definitely need a plan B for next week. Or back to baskins?
My knee is proper f*cked, the doctor reckons it will cost about the value of a white 32 GT-R to fix it. I smell a law suit :)
Willing to discuss settlements involving sisters...
Morning Mangs,
TFIF
Negatives:
Nowhere to park
No JB
Colin ran me over :)
Yeah agree it was pretty average. No idea where else we could go though :D
Oh and I stand by my version of events. You ran into my car.
Morning mangs,
anyone here at the test and tune on Wednesday ?
also, anyone know of a shop around brisbane, sunshine/goldcoast area that does wheel widening ?
Yeah I saw that, but how what when where why?
How bad?
How? With his car
What? Ran into me
When? Last night
Where? In the car park
Why? Because he's an arsehole. And also a useless pommy ranga git.
It's pretty bad hey... Doctor says I will probably lose the leg if I don't come up with a white 32 GT-R...
Emotional stress as well, that's going to cost a lot for counselling...
Strip club?
I have (totally not bribed) witnesses though.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
