Godf**kingdamnit I hope this is sarcasm :D
It's not.
I'm sure Ravi already has genital warts :)
HEY!
You're probably right
But lately I've liked the idea of filling the entire space with some massive chrome bling dinner plate style thing....... so ridiculous....... so beautiful......... *sheds a tear*
Ravi, i love you to bits.
but...
ARE YOU SOME KIND OF f**kING RAGING HOMO?!
let me choose your wheels :D
Morning Mangs,
TFIF
Positives from last night:
Ice cream was better
Negatives:
Nowhere to park
Nowhere decent to sit
No JB
Store shuts too early
Colin ran me over :D
Definitely need a plan B for next week. Or back to baskins?
My knee is proper f*cked, the doctor reckons it will cost about the value of a white 32 GT-R to fix it. I smell a law suit :)
Willing to discuss settlements involving sisters...
Morning Mangs,
TFIF
Negatives:
Nowhere to park
No JB
Colin ran me over :)
Yeah agree it was pretty average. No idea where else we could go though :D
Oh and I stand by my version of events. You ran into my car.
Morning mangs,
anyone here at the test and tune on Wednesday ?
also, anyone know of a shop around brisbane, sunshine/goldcoast area that does wheel widening ?
Yeah I saw that, but how what when where why?
How bad?
How? With his car
What? Ran into me
When? Last night
Where? In the car park
Why? Because he's an arsehole. And also a useless pommy ranga git.
It's pretty bad hey... Doctor says I will probably lose the leg if I don't come up with a white 32 GT-R...
Emotional stress as well, that's going to cost a lot for counselling...
Strip club?
I have (totally not bribed) witnesses though.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
