I realised this morning that I took the locking wheel nuts off the pig and put them on the GTR and forgot to put some normal wheel nuts on in their place. So I've been driving the 31 with 12 wheel nuts instead of 16. Should be right eh?
Morning Mangs,
Wow, I swore they were singing about the Pontiac G6 in the song...
Thank you wikipedia... you have left egg all over my face again...
Who would write a song about a heap of sh*t holden?
proud new owner of a black r33 gtst skid machine.
shall pick her up tomorrow.. mods start thursday :)
How do you do skids in a boat? :)
Jokes mang, congrats.
Nice ones. STL!!!!
Sarp mangs. In on page 700.
Of how many?
Yeah she'll be right. Thats too many wheel nuts for a 31 tbh.
lol great minds..
:) Marry Me? :)
morning post!
i'm having a 'stray'n day today to replace the fuel pump. Hope that will fix the 31
Edited by Smity42
morning post!
same here. couldn't swing a day off on my birthday, so instead having one today.
got the new call of duty, so will spend the afternoon on the couch.
Of how many?
Of 700 :blink:
Yeah I thought that too. It's alright though I just put them on hand tight and then backed it off a few turns :unsure:
f**k it she'll be right
31 Love
morning post!
Nice Mang
On PS3? I really need to buy more games for the PS3 but I hardly use it as it is...
Of 700 :cool:
:unsure::blink::P
Yeah I thought that too. It's alright though I just put them on hand tight and then backed it off a few turns :devil:
Perfect! Glad to see someone doing it right.
31 Love
<3
Nice Mang
As Marty said, too many
my daily now has headlights, highbeams, a working horn and parkers
go me
Pffffffffft too much for a daily
go me
:unsure:
Are shocks for 2 door and 4 door R33's the same? I'd assume they are?
Yep 100% the same*
*This information may or may not be correct. The public are warned not to take any advice from a Ranga Pom. This public service announcement has been brought to you by British Petroleum.
Anyone want to by a 31?
Don't you mean "Dependable Petroleum"?
I find your lack of 31 love disturbing... :unsure:
Give you a carton for it.
What you gonna drift?
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
    • hahah when youtube subscribers are faster than my updates here. Yes some vid from the day is up, here:  Note that as with all track day videos it is boring watching after the bloopers at the start.  The off was a genuine surprise to me, I've literally done a thousand laps around the place and I've never had instability there; basically it rolled into oversteer, slipped, gripped and spat me out. On the way off I mowed down one of the instructor's cones and it sat there all day looking at me with accusing cone eyes as I drove past. 1:13:20 was my fastest lap, and it was in the second session, 3rd lap.  It (or me!) got slower throughout the day as it got hotter.
    • It sounds like you want what the Toyota Landcruisers have for their roof racks. Wanna know what you end up with? Rust holes in the roof, and water everywhere...
    • Discovered today that if I select reverse first and take my foot off the brake, then select drive, the drive indicator light works and so does the tiptronic gear indicator.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Does anyone here have any ideas?   Cheers guys
