in for pg 700.
*1400
Now taking guesses as to how unfit I am. In between this post:
F*ck door trims.
For a show and shine winner, my car is an utter shitbox :(
And this post:
</3
I went for a 20min ride, and am completely f*cked. How far do you think I went?
Winner will receive 1 broken door trim clip, and possibly some abuse.
Edited by Smity42
*treading carefully*
10k's?
20 minutes, you probably rode to the park near the paper mill.
Anna its your fault he won.
Martin i can repair this door card.
10k's?
You sir, give me too much credit.
And you don't give me enough :(
Truth.
I'll hold you to that.
Passenger side I think is just about sussed. Doesn't seem to clip perfectly in the corner but its pretty good.
Driver's side I'm waiting for glue to dry on the two mounts I crimmed from my new spare trims. Will see how it holds up after that...
Morning Mangs,
How do you do skids in a boat? :D
Jokes mang, congrats.
should try owning a stagea if you think an r33 is a boat :)
2T with fuel and driver .. even boats arent that heavy :)
Edited by PetroDola
Morning Mangs,
Driver's side door trim is now holding on about as good as the passenger one. Not perfect, but at least the trims don't fall off as you open the door any more :).
that is all
:D
That's what she said.
Holy mother of god!
should try owning a stagea if you think an r33 is a boat ;)
My coon weighs a slightly less than that. Want to trade? ;)
10k's?
No Dice, Too high.
= ~3km round trip. No Dice, Too low.
3.6km Martin.
Still too low. Just think how far I could have gone if you hadn't run me down and busted my knee...
Supercheap... or the equivalent distance in any other direction.
Assuming you mean super cheap at lawnton... = 6.0km round trip. Oh my, this is going down to the wire...
6.3km
6.31km
I needed to refer to the cyclocomputer to resolve this one, I knew it was 6km but going to two decimal places, sheesh!
and the winner is...
6.08km!!!!!! It's JOHN!!!!!!!
Congratulations, you useless dole bludging bastard (right, thats the abuse coverred). You may collect your broken door trim clip tonight.
Edited by Smity42
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
