LOL!
That one was probably deserved :P
yes but at the end of my own street is a bit harsh... f**kers
So worth it. Totaaaaaaaaaaallly!
Worth it would be him giving me money, not taking it...
That's what she said!
Edited by mosquitocoils
cootha was more dead then a hooker in martin's shipping container. So next week?
st lucia salt and battery?
it's tastey. will suss out the parking in the evenings, but i don't think it will be too bad around 7pm ish
Sup mangs. Had not internet, phones or printer at work since 1pm yesterday. Everything has just come back on now. f**k IT people lol.
read about that yesterday. I think the paper is just putting its own slant on the story.
I think what the case came down to was lack of evidence by the police to convict.
Morning Mangs,
Lol. What shipping container? :D
Yeah good fish there for sure. However, I have found you are lucky to be able to park ONE car there, let alone a lot of them.
Scope it out though...
Sup mangs.
Sup.
Yay! No work :/
Damn :D
f**k IT people lol.
Hey! :D
Edited by Smity42
The bit that I don't understand is being awarded $18,000 in court costs. Wasn't he speeding ? :/
The land of goat sphincter rings delight - IN!
That's what she said.
BYO - IN!
Yeah we talked about that last night. If anyone had bothered coming you'd all know that... :D
Yeah pretty much. Couldn't actually prove how fast he was going.
hey mangs. Coffee up the Cootha was enjoyable..... wait, what??
Yeah it wasnt bad. Waiting 10 minutes to pay $4.05 for a red bull was pretty sh*t, but I have decided this can be solved by pre purchasing red bull on the way...
A few questions remain... Will it be hell busy if it isn't raining? Why did no one turn up? Can't be arsed driving up the hill, or was the rain the issue?
Could be worth another shot in the dry, but I am also keen for the plan that was discussed... :/
The one about the tight rack?
I'm not sure?
There was so much talk of tight rack, flange, box, front ends, rear ends, headlights, bolt ons, medium pace, etc. and I can't remember what was what :S
I had a late night at work last night, hence the no show, could be up next week.
Insert "That's what she said"
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
