not my footage but i did find this
im not surprised, as there was 100 mobile phones being held in the air taking video...
was actually a bit sad & desperate on there behalf... way too many wankers there... we left as it was too rowdy & getting crowded... plus the rain had stopped...
edit: it must happen often, there is a few articles/images on the net if you search "chalk hotel body painting"
Is it just me or does that look like Ravi ?
Hahaha yeah a little
im tooooooooooooo drunkk to ne - postign
mu keybosrkd or sneolne
That is the most coherent thing I have ever heard you say
Hahahahahahahahahahahaha
wow, i dont remember getting on the computer last night...
I do that all the time, usually it's facebook. I don't often regret what I write though, it's usually hilarious reading back over it hahahaha
Morning all.
Morning.
Totally.
I congratulate you an a coherent and convincing argument, I agree 100%.
That's what she said.
it is a good game, 5 years good? well thats personal opinion.
I have to stop playing it now i got work in the morning, 4 hours straight is enough for the night
Morning Mangs,
NNNNaaaaaaaaaawwwwwwwwwwwwwwwwww...........
RE: GT5 - Played Dan's copy a bit on the weekend. It was good, but not sensational. I guess after 5 years I expected more...
Mainly little things. No Nurburgring. Can't change wheels on standard cars. Limitations on painting. Wouldn't let us turbo an R32 GTS25. Graphics were also not as epic as I was expecting. (Dan will chip in now and blame the fact we weren't using HDMI output but that wasn't the problem. Low polygon count, repetitive textures, lack of detail were what was dissapointing).
The racing was certainly good though so thats the main thing. I expect when I get a copy I'll get just as hooked as every other GT game despite it's fallbacks...
RE: Ashes - F*ck Australia. Can't bat, can't bowl. Should have selected Dougie.
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
