Morning Mangs,
@Colon: Lucky bastard. Go home and get me some rum with your time off. Will bring you 2 bottles on thursday.
3 days to go for me :(
@Dan: Last day of sunshine today bro. Then torrential rain through christmas. Head out NOW.
oops too mant schooners at lunch, not sure wether i should try to work or just occupy the crease and minimise mistakes lol :domokun:
Love it and hate it at the same time.
The latter for sure.
+1.
So, apparently it is snowing in N.S.W. & Vic. In Summer. Must be a sign of the end of the world, I was so hoping for zombie apocalypse too :(
forecast for their area is not to come into heavy rain until saturday, tommorrow is sunny with possible light showers in the arvo.
Anyone know how far a car can be stripped but still be roadworthy / registerable?
Have gotten bored over the last few days and have ended up with no interior :unsure:
just strip the hell out of it, if questioned say you parked it at Logan train station and this is how you found it an hour later...
hahah, yer thats pretty true. just make sure you got lock nuts on or the game would be up ;)
so col? a 35 eh? care to elaborate?
i think holding back the smile as you told the story might give it away...
cause i would piss myself trying to pass it off as the truth...
2011 blue premium, expect delivery in March at this stage...
I should elaborate its not mine as in im not paying for it, but its living with me... :ninja:
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
