Morng mangs!
Anyone know the size of the stock RB25 turbo inlet? Is it 2 3/4"?
How hard is it to get some piping that will go from the stock intake up to 4"? Don't know the first thing about where to look. Or could I just use a silicone joiner that goes from my intake pipe -> 4" inlet on a new turbo?
Morng mangs!
Just about any performance shop should be able to make up something for you.
I don't think you'll be able to use a silicone joiner as the stock intake pipe is plastic. If you use a pod you MAY be able to clamp the stock intake onto a short bit of ally the right size then use a silicone joiner to bring it up to 4". But that will be a big restriction in the inlet...
over 9000
This.
Morng mangs!
you can slide a 2.5" pipe over the inlet nicely. I did this with my old setup on the Telstar. Cut 2 slits in the pipe and clamped it to the inlet.
I cant find a pic of it, but if I do I'll post it up.
short bit of ally the right size then use a silicone joiner to bring it up to 4"....
Marto's penis enlarging tip #103
col goes to toowoomba this morning early left home at 4am...
col does his days work with the hope of getting home early to play ps3...
a piss load of rain falls, tbar range get closed due to land slide...
i take the DR route, so does everyone else...
get back to the highway some hour later, its flooded over at Heliden...
col gets home at now whe i left there at 2pm :(
Wait.... oh
How does getting whacked in the testicles affect your right hand...... oh
FKN LOL
I also hate rain and being in places that require some travel. I'm lucky I wasn't in Rocky a day later than I was, otherwise I'd still be there.....
im lucky i left my girlfriends place when i did. 2 days later the weir river cut the road so now the skyline would have no chance of getting out, i need a 4wd
@Colin: Contact this guy: http://motamota.r31skylineclub.com/index.php?topic=132962.msg1525770#msg1525770
Also @ Colin: I put fuel in the Pergeot, it took almost 55L and wasn't even empty yet. So yeah, it just has an epic big tank for a small car.
Also @ Colin: Are your rims 4/5 stud or just 4 stud? I may actually be interested if they are 4/5...
So we could get 5% off if we get 4 turbos high flowed at te same time by hypergear. He starts back at work around 8th feb...
I don't know about Colin but I'm 100% stud ! LOL
Well that's like $50 off, which is not bad, but not good enough for me to wait around till the end of January. I'd rather pay the extra $50 and get my car back on the road sooner...
So if you can sort out your four so we can send them off next week them I'm in, otherwise I'm out.
Thanks Dude :)
@Colin: What was the name of that tuning place you were telling me about?
It doesn't matter if you wanna pay more or not, he's not back at work til the 8th
Unless you were talking about someone other than hypergear?
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
