When replacing my turbo, what gaskets do I need?
I'm thinking:
Manifold-> turbo gasket
Turbo->dump gasket
Oil return gasket?
Am I right that the oil feed doesn't need one?
Turbo->dump gasket
These. Althought they are fairly sturdy gaskets and if they are in good nick you might be able to re-use your current ones.
Oil return gasket?
Should just be able to remove the oil return hose so shouldn't need a new gasket here.
You should replace all the banjo bolt washers on the oil feed/water feed/water return. That said, a lot of people probably don't bother, but they are not very expensive so I would.
Just take the banjo bolts to enzed or something and ask for banjo washers to suit.
What exactly IS a banjo bolt?
There will be one on each end of you oil feed line, water feed line, and water return line. So 6 banjo fittings, needing a total of 12 washers. The sizes will vary, (some will be the same some different) so you will need to work out the sizes you need when you pull it off and then take them in and say "I need 4 of these ones, 8 of these ones..." etc.)
The oil return line is just a normal clamed hose. I can't remember 100% but I think the gasket you are talking about for that one is where the hose fitting connects to either the block or the turbo. But you don't need to undo it there, just undo one of the hose clamps and take the hose off.
EDIT: That picture is a little misleading, the washers are not actually copper washers but 'banjo washers'. According to the dude at Enzed when I went anyway...
Edited by Smity42
Ok so I -might- be able to re-use those washers, depending on how they look when they come out?
Should I drop my oil before I do this? Or will it just be a small amount of oil that comes out of the feed?
I should drop my coolant though, yes?
You are NOT supposed to re-use the washers. They crush when you tighten the bolt and that is how they seal. Once crushed you are not meant to re-use them.
I think some people do though, but its a bit dodgy, and you may end up with leaks.
It might only be 31 owners that re-use them...
Should be no need to drop the oil, just let the car sit for a while so that most of it drains back to the sump before you do it. You may spill a small amount but nothing much.
Water... Can't remember. You will probably lose a fair bit of it so put a drain tin down, but theres probably no need to drain it entirely. Just fill it back up and bleed it when you're finished.
Been shut for a while for the airport link work. Maybe it was only through certain hours...
Did not know that. Must only be certain hours...
I meant on the turbo where the oil return goes in (i think thats what it is, not sure) there's like a flat surface area around the hole - looks like it needs a gasket.
Burson have a turbo gasket kit with 2 metal gaskets and 'about' 4 cork ones for $50. No washers.
What's the enzed place you mentioned?
Edited by mosquitocoils
Ahh... if there is something there that you have to transfer from your old turbo to your new that needs a gasket, then yeah you will need that.
NFI what those cork ones would be. Pics?
2 metal ones would me manifold-turbo and turbo-dump I reckon.
enzed (http://www.enzed.com.au/) or pirtek (http://www.pirtek.com.au/) or any other hose joint really. I didn't get a mobile guy out, I just went into a store.
been up in the copper today again, brisbane is a sea of activity...
people, cars, trucks everywhere...
seems business is back to normal for the major shopping centers...
hope the people who bought 20 loaf's of bread die eating them, wankers...
Yeah I'll just suss out what I need to re-use when I get to it I guess.
Twas over the phone my good sir so no pics, but I was guessing the same as you.
So, good thing no one went to old Baskins last night...
XF and 33s would have gotten across that...
Are we allowed to pick women folk in the mens cricket team? I reckon this Elyse Perry chick bowls better than ANY of the blokes do...
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
