Keaton, that is way too epic for my needs. I only need an internet browser and a media player on my computer. I'm not launching space shuttles!
Naah, this is what you need to launch space shuttles:
Yes... I need to get it upgraded to Win7. But cbf.
Baha it's not that epic!
For 4.5k I'd want a pretty epic laptop. I might be biased though because I get this one for free. But yeah seems pretty exy to me.
Edited by Smity42
f**king bent the fuel rail taking it out, and lost one of the little plastic washer things :(. FML.
Anyone have a spare RB25 fuel rail? Or do you reckon it will straighten up when I tighten it back down?
Where and how did you bend it????
Trying to do things without removing stuff???
I had a print out of a tutorial i found on here, but pictures were small and in b&w so hard to see.
They said to remove 3 bolts holding the rail in then pull it out... I actually found 4 bolts, then I tried to pull it out.
Turns out there was 5... one was nicely hidden :( :( :(
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
