Sup,
Back in Brisbane for a Job interview this afternoon, then back down the coast for the rest of the week. Had the HICAS light come on while on the highway. Pulled off to get some water, light off. Back on the highway and 20 minutes later light back on....grrr! Then, just to make an absolute ass of my self at the first red light I come to in Brisbane I turn the engine off to reset the HICAS light and the damn thing wouldn't start up right away! Bloody turbo timer and kill switch and alarm causing me havoc and backing up traffic on Coro Drive.
I vote me for dumb ass of the day!
Could just need p/s fluid
I thought it was only the 32's that shared the power steering with the HICAS? Isn't it all electric in the 34?
Yeah I'm not sure, you're probably right.
I just know if I saw those symptoms in my 31, I would check the P/S fluid level :)
Hi scott, guess you didn't expect some crazy guys in an Alfa to be on the horn at you. Really need a brumby 4 speed
My parents have had 2 seagate drives fail, my mate had one that never even worked properly from the store. They had a bad(relativly) batch.
Haha! Yeah, I was thinking WTF is with this guy... Look over and see you giving me the international peace sign. Pity you weren't doing 3G......inverted. haha
do holden use the VDO headunits in the commo? you guys getting issues with the sat nav and AM reception on those units?
In news today, offically have been promoted at work to head lotus tech/senior technician, also been given a payrise.
Hahah yer scott i couldn't resist! i thought you would have been freaked out a little.
Pretty sure the brumby has broken something in the box, when you accelerate it sounds like a clicking CV, when cruising along it makes the same noise / bearing noise also but that all goes when you push the clutch in and coast along. So im thinking i'll get a good condition gearbox and a new clutch to throw in, i'll also replace the CV boots and inspect them for wear. Thoughts?
Congrats! Top stuff.
Thoughts?
Tell her to sell it for scrap metal and buy a real car instead
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
