Went to archerfield to watch the drifting today, theres certainly some colorful characters out there, including a guy that looked like snoop dogg.
Now that I have sunburn that has turned purple I'm thinking I'll probably pack the sunscreen next time
Back in Brissy now :)
What's the plan for Thursday night? BnR at Chapel Hill? Steak?
It's also time to start getting some work done to my baby. Going to see if Fulcrum can have a look at my suspension some time this week, it has Tein Coilovers and an EDFC but I want to get it all checked over and get the car raised slightly so I'm not bottoming out all the time and I can hopefully eliminate some of the god damn wheel rubbing as well. Then it's off to Chris Rogers to get the Sat Nav/DVD/Radio all sorted. Once that's all done I need to find a decent workshop to get a full service done and get it up on a dyno to see what sort of power I'm making and where we can go from there.
I'm thinking the order of work to be done is as follows:
- Exhaust, 3" turbo back... currently have at least a cat back with a 5" tip but there are some exhaust leaks according to the pre purchase inspection I got done.
- Intake (not sure if I want to go pod or keep the stock air box yet)
- Z32 AFM, Nistune ECU, return flow FMIC all in one hit. Possibly get the standard turbo up to 9-10psi at this stage as well but I'm not sure how well that would go, the car has done 140,000km...
- Get the gear box shift kitted, strengthened, high stall and a cooler put in (it's an auto)
- Miscellaneous systems upgraded/replaced (fuel pump, slightly larger injectors, new coil packs etc)
- New Turbo - thinking a HKS GT-RS. I'm not looking for a monster level of power, more around the 230-250rwkw level. From what I have read the GT-RS will do these power levels safely but still give decent responsiveness without huge amounts of lag.
Thoughts/opinions on the planed upgrade route?
keep the airbox, and get an Apexi panel filter for it. Stock turbo will hold 10-12psi nicely, with a decent boost controller everything else on the list looks pretty good to do them power figures, guessing your turbo is the stock 34 item with the OP6 rear housing if it is then just send it away to get highflowed rather then spending big $$ on a HKS item.
Fixed the brumby today, LH front driveshaft was stuff, while i was under it though i found the rattle, tail shaft uni is buggered :( the list never ends
Sarp mangs. Successful weekend was successful. Tree cut down out at mum n dads place, bike serviced - new air and fuel filter and some new plugs. Still has a miss high up though so I'm thinking the carby needs cleaning/ignition problem? Also did an oil change in the 32. Nearly 15,000kms between oil changes >_< Still going strong though :worship:
Keen for Star Wars. Pay day tomorrow :cheers:
Morning Mangs,
New week, 5 days till the weekend :(.
Skrackin?
Work :glare::down:
Hai Guys :action-smiley-069:
How was the weekend???
Starwars Tursdy night? tobesure tobesure..
Work :ermm::(
Morning.
Bored at work
I've done pretty much no work today. Bus driver dude isn't there, so i did the bus run as soon as i got to work at 9. By the time i got back it was smoko time, then after that they sent me to newstead to get keys to take the the locksmith that i'm at now. Then after this i go back to newstead to get more parts, then back to windsor. By then they'll probably have another mission that will take me up to lunch time.
All in all a good morning so far :thumbsup:
Hahahahaha nice John
Morning mangs
Spent the weekend camping at a doof out west... feel strangely rested and motivated, despite partying all weekend haha. What's news around here? Can't be bothered reading back over the last few pages lol
Morning mangs
The skyline world ended as you know it.
Refer back a few pages for more details.
Had a proper poke around under the hood/car for the first time today and was pleasantly surprised by what I found :)
Full turbo back exhaust by CES Racing including a split dump pipe and an after market panel filter in the air box (although it is FILTHY, need a new one). That's points one and two taken care of on my list! Got the car booked in with Fulcrum on Wednesday to sort the suspension out then I might give CES a call to see if they can sort the exhaust leaks out and I'm laughing.
Damnit, I can't believe I fell for that
Score!! Suspension will probably make you feel a lot better about the car than power upgrades right off the bat after an exhaust. That's where I'm heading with my baby soon..
Who wants to volunteer to strap them selves to my suspension so I can find out where my noises are coming from?
haven't moved yet. Let's just say i know the 2 people i'll be living with, you have been there before, and its a car friendly house
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
