down down prices are downnnnnnnn
It's funny in one of those ads, I think it's the current one, there's a young guy singing the song at the end of the commercial and just before it cuts he starts singing the song again.
There's a "secret" PDF document going around about apparent pole shifts on march 15 which will wipe out Australia and surrounding countries.
Just thought I'd point out that there's an email address on the top of it, results point back to a film making company.
I for one am going around telling everyone it's real, for the lulz.
Morning Mangs,
Got a bunch of nissan parts last night. Might put injectors and fuel rail in tonight. Have sent an email to hypergear trying to find out where my turbo is at...
I just remembered: The security guard on the gate this morning said my XF was a "Nice old rig" (or something like that). I didn't know what to say, it's such a shitheap. I just laughed.
This morning i got "cool car". Maybe I should try to sell it to him?
5:40am is my wake up time now.
Martin check you mobile messages and get back to me asap i need to order these nuts
8am start! You lazy f**ker....
Edit: Punctuation is important mmmkay.
Edited by Beelzebub89
Used to get up at 6am for uni (hour of messing around getting dressed and eating. i'm slow in the mornings) and an hour to get to uni... for 8am starts. 3 f**king years of uni and 8am starts for every one of them. until this year! Go go lazy uni student mode!
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
