Hello IT
Have you tried turning it off and on again?
The button on the side is it glowing?
Yeah you've gotta turn it on.
Push the button!
<IrishAccent>
Ah! There you go. I just heard it turn on.
</IrishAccent>
What do you do?
Lots of stuff :P
Technically I'm a consultant working with engineering information management systems.
ATM I'm working on an upgrade project which is about 9 months work crammed into 4. Totally awesome :down:
My boss bought an iMac
I now have to support mac's OS on a windows domain
FML
Sucks to be you.
Urgh.
Didn't get much sleep last night because we lost power in the middle of the night. This set one of the smoke alarms beeping (they are wired to mains, I guess this one had a low battery or something) which woke me up.
When I managed to get it to shut up I couldn't get back to sleep because it was so f**king hot (no air con or fan with power out).
Feeling it about now :(
Sux2bu
Apparently we had a storm last night. Only time I woke up was to tell Sandra off for closing the window.
Someone provide me with the motivation I need to go to work. New job in 10 days, zero enthusiasm for my current one.
Get your arse outta bed and get to work you lazy fark!!!
It's like... eleventy billion degrees in the workshop today :(
Should work in an awesome air conditioned workshop like dan ;)
Sux2bu
I woke up at around 3 to the door slamming, brutal wind was brutal. I sleep well when it's raining.
John, still good for Saturday!
Yeah about 3am was when i got woken up. Got back to sleep at about 5, then had to get up at 6 :(
+1
see i have the window open when i go to sleep, that way you get fresh air. kyle thought it was your car alarm going off.
pulled a 'stray'n day today, sorting some things out
It's like twelvety billion degrees in Cairns today, way too tropical for me.
Watcha doin in cairnz?
I opened the windows when the power went out, I'm not an idiot. But without even a fan to move the air around it was still way too f**king hot.
Get Netbanking! Joo owe me rent money.
Also, can you swap my battery charger over to the other battery please?
For the first time ever in my working life I have two of these planned for next week (never chucked a sickie, only taken 3 legitimate sick days in the last seven years.)
Taking a half day to meet with the owners of the new pub I'm off to manage and a second half day the following day to get my baby serviced by Dan at ERD. The company owes me 460 hours of sick leave, they can pay me out 16 before I leave next Friday.
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
