hai guys. long time, been busy being busy. Nambour, Cairns and Lismore this week. pah.
Squeally, laggy, broken stock turbo is squeally, laggy and broken. So close to this \/. Time for Hypergear.
This is like pictionary. Guess the phrase and you could win a Freddo ;)
Plz bring my ECU tomorrow :). Even if its not finished, I'll finish it off myself. Thanks :thumbsup:
Beware of ninja cats toting shurikens?
Not quite.... Was something to do with the turbo shooting a ninja star into the cat....
Ok :/ The 32pin ROM is being a PITA....
Thats what all the ladies say to you don't they...
Got it in 1 :thumbsup:
On another note, I stumbled upon this most excellent artwork.... Pushes boundries for work safe...
Can link more if needed.
You know it.
...Wait, what?
I see what you did there...
Not much point saying pushes the bondaries for work safe and then dropping the pic straight after it... link to things like that please :)
Back to Uni today... one of my two days off a week and I get to spend it surrounded by brain dead 17 year olds... Why do I do this to myself?
Also, Iced Dairy Confectionary tonight? Who's in?
Uni Hotties?
In.
Uni Hotties?
Uni hotties are all too young. Feels creepy trying to chat up a girl when she's 10-12 years younger than I am.
I'll be at BnR around 8-8:30. Having dinner with a friend first.
Speaking of Uni Hotties, the last two afternoons have been pretty fail at UQ. Was hoping for a decent turn out seeing as the temps are through the roof.
Might have to wait a couple of weeks for the new ones to settle in.
I cannot understand these words you are saying... it just doesn't make sense...
Uni hotties are fine to perv on, not so fine to try anything else. By the time I finish my degree in 2015 I'll be twice the age of most first year students.
Besides, I'm about to start work as a manager at one of the biggest pubs in town. Just as much eye candy and they aren't as young and a lot more boozed ;)
    • Well, yes, every CU on the bus is available via the Consult port, but whether the scanner you are using is capable of talking to the TCU, the ABS/TCS modules, etc etc, is what is at question here. Many of them are only for engine codes. So, if you have one of those, you won't know if the ABS is having a bitch.
    • That's now. R chassis Skylines come from a time when the tolerance in the ADRs was a bit more....slack. My car, on 235/35-17, which is damn near the exact same size as the original 205/55-16, is pretty much bang on correct indicated speed across the whole legal range. That's demonstrated with constant speed run over 5km, and GPS speed. It's just the luck of the draw. My particular speedo head has to be the thing that is "calibrated" that way, because everything else (the diff ratio, the gearbox and the speedo drive**) are all same same as most other Skylines. **OK, so the speedo drive is a Navara unit to drive the R32's cable, not the electronic unit than an R33/4 would normally have with teh same gear on it. Otherwise, I applaud your OCD tendencies, and I would do the same if I needed to.
    • Not too sure, I believe the Nissan consult port does everything? Also just filled up the reservoir to full and the light is still on. The float seems to move up and down fine.
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph on 255/40 17, so again conservative Google says manufacturers need to set the speedo from 4 to 10% slower than actual road speed.....for safety.....and compliance  After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
