Moved my mates furniture into our new place today. Quite tired. Fark there were some good drivers on the road today.
Had one woman sit at an intersection while I was giving way to her, she sits there for about 1 minute so I just went for it thinking she didn't know what she was doing, and has a go at me.
Coming up to a roundabout car in front of me has all the opportunity in the world to get in, drives forward and slams the brakes on ffs
A few minutes later some woman is yet again taking forever to go through an intersection, she's too busy reading the paper while she's driving.
And those were just a selection of the drivers I've seen today. Fark.
On the plus side I saw a nice white 33 gtr. Want.
We should do the breakfast thing often...I was close witness (Real close, farking track blockers :P )to the most epic dragrace of all time...the sexf wasnt that far off the pace!
+1 defiantly do the breakfast thing again. Well worth the drive down. Let me know when the next one is on and i'll be there
Noel cheers very much for the day out, had a great time on track.
+1
The fruggin tow truck was faster than the falcon. :teehee::banana:
A drunk on a treadly would be faster than the 'coon.
Helluva fun day out.
+1
Went back home and took my mate in the magna out learning auto in the 'line. Didn't work to well (he didn't spin it though)
Less spins is good :thumbsup:
+1
It was so epic that those behind did not even realise it was a race :P
damn right, if he was on 98 it might have been a closer race too!
You know it, those 4 octane points made all the difference.
Anyone got suggestions for a new radiator? From what Noel was saying the OEM ones are around $800 and he was saying Dan can source a new one for the $400-500 mark. I checked out the PWR ones which are $850ish and have options for in-line transmission and oil coolers which I like the sound of.
Any other suggestions or brands?
Is the ones Dan getting OEM? If so I'd get them.
how would you guys feel about doing an evening track cruise. I like the idea.
f**k Yes
noel keen for evening track cruise
need more notification so i can get the car in better shape
Chuck Norris is always prepared. (add ninja emoticon here)
i may have a chuck norris beard but im no chuck norris sorry :(
haha yer i need to install some new parts. Still happy with how i went today though, able to keep up easily through the corners, just the lack of power on the striaghts left me alone
cooling pro from just jap, around $400 and you get to keep the shroud and standard fan
http://www.justjap.com/store/home.php?cat=300
Morning Mangs,
Disappointed I missed out on Sunday. I was far too f**ked on Sunday morning. Should be a good day today though :thumbsup:
German Club Wednesday?
Morning Mangs,
That's what she said.
Keen. Especially if Keaton drives me :)
F*ck mondays :(
I should be able to, we could meet at Johns as I'm
In albany creek or I can come pick you up if it's on the way.
Feckin iphone
Edited by hylian
I'm at Petrie, so its not on your way really :(.
Meeting at John's however means that someone still has to drive home from there, which is fail because it means no beer.
Unless you can pick us up and drop us off at a train station? Carseldine/Zillmere/Geebung seem to be the ones near John's
I'll investigate bus's to Aspley now.
We're assuming of course that John actually wants to go...
You'll have me + Dan probably, and maybe Kyle, coming from Petrie.
Feckin iphone
Truth
Back down at Yatala. Waiting for Dan to arrive so we can start figuring out what's f**ked and what we can replace it with.
I'm pretty sure it's your radiator thats f*cked hey... :P
OK bus to aspley looks like it won't work, transinfo is giving me nothing that will take less than 1hr 10min :(
Kyle is out because he has uni, but that means he will probably be able to give us a lift home... So if you could pick us up from one of the train stations and give us a lift in that would be grand :)
    • I'll get one of these also just for giggles
    • I bought 6 new spark plugs to compare readings. They will be here tomorrow and ill see if meter is far off if it all. I know one is at least reading 0 so its best replace all anyway if one is bad, from experience. I still have to test the harness just to be sure its not a double issue and I waste my time haha-the old plugs are iridium I always thought those lasted more than 50,000 km.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
