Booked in to drop car off for a tune on 2nd april :( Couldn't fit me in while I was in Melbourne.
Never mind, that's the first weekend when I get back, won't be driving it much before then anyway.
Holy shite!! He aint dead!!
Hahah... Nah unfortunately for some Im still kicking :)
Ive just been avoiding the forums since the 34 was sold :( Though I now have plans of getting another in the not too distant future so I though I should get my ass back here for a look!
have opened my window so I can see and hear it all better, and, to add further to my lolz, the guy is german, and swearing his ass off
Lol Video plz could be worth 10k
bah, didn't even think of that. was too busy giggling my ass off.
he was flailing the whipper snipper around like thor's hammer, whilst swearing in german and occasionally yelling in a strong accent "DON'T EVEN THINK ABOUT IT" sounding like Arnie gargling roof nails.
all settled, the dog owner eventually came out to see what the yelling was about.
