I was fine when I was waiting for parts and waiting for them to be installed. It's knowing that it's all back together and all working and driving just fine (just not as efficiently as it could) that is killing me.
Well fret no more. They now have it. Not sure that it will be done today but it's turtle-heading
You just made my day Dan the man!
*Does a happy little dance*
Reckon I'd be fine to swing down tomorrow arvo to pick her up?
It's got a new Nistune ECU in it.
Good choice :thumbsup:
Nice power from a lightly modded 25 I must say :) I'm going to be happy if I get around 180-200rwkw.
Yeah really happy. People have got around 250rwkw @ 18PSI out of the same turbo, but probably have a less restrictive intake. Also i believe EFI's dyno reads a little on the low side. So I'm stoked.
So, seeing as it's driving so great, you going to come out for a drive to Jacks?
So I can hard park it? Negative. I've got to go round to Dave's to pick up a shroom for Scott, and help (read: supervise) Dan getting Dave's clutch working.
It does read a bit lower than most, at the majority of places around you would make 10 to 15rwkw more i reckon.
Don't think Dan can make it now. It's not like I need to drive the car to work tomorrow or anything :whistling:
Which would put it pretty much bang on that 250 mark :).
Roger. I'll swing round anyway and grab 'shroom.
Noel if you go to Jacks let me know, It will give me a good reason to clean my car
yup, no work again tomozz so Fat Alvin will be rollin in...Be hatin
Village square it's called. Enter carpark beside JB-HIFI.
I laughed fairly hard at the idiot who ripped the bottom out of his super low S13 about a month back. He tried to cone in over the big speed bump at the other side :P
hey does anyone have an r32 actuator (10psi) and if they want to give or sell (but mostly give) can they please bring it to baskins tomorrow? or a boost controller/ tap for the right price :rofl:
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
