Off to work now post.
Also, more track time = hells yes! I really need to get to work and lower my seat down so I can fit in while wearing my helmet.
I got lowered rail and seat... now I cant go far enough back :down: Getting some brackets made up this week.
Your seat will probably cease to be ADR approved if you do that. Also, you will need a mod plate once the brackets are fitted
yay for being short!!!! haha do need a more supportive seat tho bracing a knee against the tunnel isnt the bestermm.gif
Don't push me cause I'm close to the eeeedddggggeee
I'm try-ing not to lose my head
SARP. Just watched some UK documentary on GTR's. Was ok.
another one for you to watch if you havn't already.
Nearly finished my super greato awesome extreme terrific multithreaded loader app. Phear my l33t programmer skillz :P
I fear boredom is imminent now though :(. Might copy pasta my coupe build thread from 31 club to sauqld forum...
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
    • Unfortunately the cavaet to that is that while any scan tool should be able to read the code, the workshop will need a consult plug to OBD socket adapter. You don't have a location on your profile, where are you based?
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
