Not our fault you needed to strip so much weight to get it to go fast that you had to remove the windscreen which then causes the *warblegarblwalahblagh* face when you try to talk :P
ooooh, that's a *snap* right thur
Added a new DeLorean to the collection today!
(Second from the left)
saw a real DeLorean on the way onto brissie the other day. was painted metallic blue....ewww
Morning Mangs,
Stayed up for GP and then to watch Cadel Evans win the tour last night. This morning sucks.
What time does the action kick off at QR tomorrow?
It seems that the vunder kid seems to crack a little under pressure when things dont go his way. And for christ sake can Webber actually manage to get a good start for once.
I've always thought he's a bit sh*t in the field. Only good if he can drive away in clear air. Unfortunately he seems to get to do that a lot.
It would be nice, but the start didn't cost him the race this time. Hamburger and the Fiat driver were just faster.
Action starts at 8, driver briefing somewhere between 7 and 8. I'll be at Macca's at Yamanto around 6am and leaving at 6:30 if anyone is keen to join me.
Too early. I might try to leave home around 6:30, if I manage to have a nap this arvo...
    • I'm only really familiar with the R33 setup, the factory filter is very much an encourage fuel pick up thingo.  The factory pump sits about half way down into the tank and the sock runs down into the bottom of the tank.  Mounting an aftermarket pump in the factory location with the typical tiny Walbro filter, I had huge fuel surge issues once the fuel level dropped below 50%.
    • Hi Gent, Got my r34 GTT 1999 ,wondering if anyone has a stock airbox with snorkel? currenly it has a pod filter which im planning to remove and install the stock part, as this needs to go to vic road for inspection. Appreciate your assistance.
    • Yeah, I still dunno. The size of the sock should only matter if it is blocked. It is, after all, a filter rather than a "thing to encourage fuel pickup". He has modded the original so that it is now down on the floor, so it's not physically the same as in the original complaint, yet does the same thing. I therefore lean to the problem being somewhere else. Sticking some dynomat on there is a worthwhile experiment, but I'd put $10 on it not fixing the problem.
    • I don't remember hearing it before the coolant and bonnet escapade. I wonder if a couple of pulleys being filled with hot coolant was not to their liking?
    • Took her down to be the wedding car ❤️ and I love the people’s advice 😂
