Particularly now that the general instability has gone (well, give it a few weeks for this to blow over) i think you'll find gold is actually a pretty bad option. Though you've done well in the last few years, on average it doesn't seem to go up as much as the share market does, i think.Or something. i'm not a professional.
when the share market goes bad gold goes good
Morning Mangs,
Hey, McFly!..
...yeah
Looks good!
Wheels don't look multistud though
Me likey!
That's what she said.
Throw in a cat with helmet cam. :thumbsup:
LOL! Don't have a cat, or that would have been an awesome plan
Moaning ho's.
Might take apart the cross over pipe today and replace the valley cover.
That or I might spend all day on the couch.
Ah, the agony of choice. What happened with those 2 jobs you got offered?
R34 is apparently a bit harder due to TCS, etc.
Bored.
Need nets, saw my old batting coach. Need to practice this new stance and 'trigger movements' that will apparently get me back on track fast.
Will you be around this weekend?
Batting coach. Need one of those.
Yeah should be.
I found mine from back in the day. Had a quick catch up.
Cool I will be in contact and see if we can organise somthing. I will see what Gerv is up to as well.
    • Messing around with. Twin kit for. Rb30/26
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
