Ah summer. I hate it with a passion but it does bring three good things with it. Cricket, short shorts and singlets for all the ladies, pool parties with cider and daiquiris. the rest of summer can go f**k off and die.
yeah it will. but lucky our games dont last long :P
Lol, true.
I wholeheartedly agree with this statement in its entirety.
Where were you last night?
I has aircon in most rooms, just not the garage :(
Also, air con does not work outside :(
I have an aircon unit for the garage!
Just do what I do and dont go outside for 3 months! lol
Lucky Bugger!
I try not to go out too often, but sometimes it is unavoidable. e.g. Cricket, Motorsport, not being a lamer, etc. :P
