Morning Mangs,
She's in engineering for the next couple of months.
Damn :(. I don't want to know how you always know what she's doing, you creepy stalker.
She definitely needs a rape whistle.
Agreed. No wait, don't give her one of those...
Martin, sounds like you haven't had a bit of a with this chick before nyaanyaa.gif
I read it a few times, but I still have no idea what you are trying to say...
I will assume you are giving me sh*t though, and I put it to you sir, that you sucked off a horse
:P
God-like abilities.
That's what she said.
Speaking of the ladies... do any turn up for icecream on thursday?
Was trying to get my misses to come with but I'm having a bit of difficulties on the persuasion
try this :domokun: repeat until she agrees to attend.
Will the kitchen sink fit in the skyline?
Lets put it this way... not many come more than once :P
A fair point, good sir.
I beleive both Natalies have also clocked in more than one appearance, and Alyssa (John's missus) back in the day.
But that would be about it...
WTB: a decent frigging immune system. eyes watering, nose is running like a tap
my mrs likes ice cream
Might show up one day if we ever have a street car.
Showing up for ikes cream doesn't mean showing up for it in a skyline...
Or you could just rock up in your thing anyway.
Edited by sneakey pete
Too much of that crap going around at the moment... Some pretty bad stuff. GL mate
Do it. You skirt.
Anna has showed up twice at least
I thought it was only once, but I'll believe you. Twice ey? That's gotta be about as many times as you've shown up :P
Hey dudes. I'll be coming to ikes reem tomorrow night hopefully. Richie, tell your other half that if she wants ice cream this week, she can get it herself lol. Remember, BUTTERSCOTCH!
You gotta check out my new headlights too! Polished them. omfg. *fap fap fap fap*
I should hopefully be there with one of my trademark short but sweet appearances.
Might even get some ice cream instead of pringles and dr pepper this time
Well at the moment showing up for ice cream would mean havIng to drive a Patrol an hour each way. Driving a Patrol for that amount of time without a track day in the middle is not something that any human should ever be subjected to.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
