Well at the moment showing up for ice cream would mean havIng to drive a Patrol an hour each way. Driving a Patrol for that amount of time without a track day in the middle is not something that any human should ever be subjected to.
If you want to come, drive to my place and ride shotgun :thumbsup:
P.S. When are we going to see Senna?
I have no idea. For me, prob when it's on blu-ray. I think I have a spare weekend sometime in October. >_<
P.P.S Morning Mangs, TFIT.
Agreed. I'm on holidays from tomorrow. Not much of a holiday though since I'm now moving house. Made worse by the fact that I destroyed my back last night with some over-zealous sexy time.
Speaking of which, what are you doing Saturday? :whistling:
Hey dudes. I'll be coming to ikes reem tomorrow night hopefully. Richie, tell your other half that if she wants ice cream this week, she can get it herself lol. Remember, BUTTERSCOTCH!
You gotta check out my new headlights too! Polished them. omfg. *fap fap fap fap*
Show us your car man - I'm pretty much on Holidays this and next week :D
I should be able to get Yen to come... Meet up before hand again dionacle?
Bummer.
I'll hopefully be getting a week off soonish too :)
Thanks for the offer bro, but you're really not my type. :P
If you want me to help move though, well you're somewhat in luck. Saturday is my first semi-free day in about the last month. I've got to work again on Sunday :angry:
I think cAndy is organising some cricket Saturday, but I should be able to give you half a day. Not sure which half yet though.
Of course, you're welcome to borrow the ute for the whole day if it's useful to you.
Suit yourself, fag :P
I'll send you a text on Saturday morning and let you know if any assistance is required.
Ice Cream!!!! Haven't been in ages and the car is actually clean!!! Just a matter of whether I bring the girls or ride solo tonight...
No way.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
