Sarp mangs. Extended absence from here since work have the audacity to make me work while I'm there...outside pirate.gif. Cheers for all the birthday wishes...I think. Rangas get birthdays based around the leap year. Normally the year before, year of and year after the leap year. Just to clear up any queries. How's the weekend going? I ended up hammered on Friday motorboating many boobies at the Cabaret club and Love n Rockets and it was all paid for cheers.gif Great success.
Nice one Colin. Sum of my weekend.
Happy laps was awesome. Gokarting was also awesome. BBQ was awesome. Damo breaking all my shit was not awesome. Doing nothing today was awesome.
This seems to be a common thing when SAU guys come to your house, we break shit. sorry i couldn't be there, had other things on.
Anyone want a free R31 shell? straight car, tiny amount of surface rust. Free come pick it up. Get free shit. Colin?
If only it was a wagon I would take it.
Morning Mangs,
Shut up, Vettel.
:P
Sarp. Me too :(. That's far too many birthdays. Weekend was good, not as many boobies though :(.
Happy laps was awesome except for:
A) Brakes not working (expected)
B) Air fuel guage not working :(
C) Clutch slipping :( :( :(
Go karting was awesome. Might have to re-asses my opinion of Kingston park, maybe I just got the shit blokes last time.
BBQ/Drinking was also good.
Drive home was too long :(.
Putting new brakes in yesterday was not fun, but at least it is done now :). Also fixed Air fuel guage.
Bled the clutch while we were at it too, because the fluid had aids. But I give that a 0% chance of fixing anything.
Nice one Colin.
That's what she said.
shit bloke, that guy. Hope you had a good day/night other than that :thumbsup:
He was not even an SAU guy
Bros b4 hoes Dan.
Double the wagon love.
i think you should still take it anyway.
I thought it was meant to be your track car Dan?
You'll never guess it; he changed his mind again. He now wants a faulty chassis.
Go kart videos are uploading now, will link them when they are done. I forgot to put the spice girls music on them for Scott though :(.
Will try to get the happy laps one done tonight. Maybe that needs some spice girls...
Wow really? Dan changed his mind?
a fiver says the faulty chassis never happens
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
