Split into 2 posts because SAU is sh*t, Race 2 and 3:
I can't watch them at work so I can't see if there's anythign wrong with them, or how much quality utube has sucked out of them. They lost a little bit of quality when re-encoding them to a sane size for upload, but not too much.
Camera is aimed too low on the first vid (my bad), and the sound stuffed up on one of them for some reason.
Most interesting bits are probably my killer first half lap in race 1 and Ben being a sh*t bloke in race 2.
Mangs
Shit weekend was shit
Next one is bound to be the same as I will be in Bundy.
Go karting looked fun. Pissed off I missed out on all the festivities.
haha looks like a bit of fun @ gokarts... nice laps Martin
Was good fun. Laps were OK, Joel was on fire though.
Mangs
Sh*t weekend was sh*t
Sorry to hear mang :(
We should do German club again soon
Morning Mangs,
My vid of happy laps is up, check the event threads.
Ace McFly. haha
That's what she said.
Time to get off the PC to take my 34 in for it's 100km service... $1000 ggoonnneee
Man, how shiny is your bonnet :P
Fark that silver 34 took off @ 1:20 (Also noticed the mute here :D)
Man, that is FUNNY shit @ 10:00 - how fast does Noel fly past lol.
Haha... man, I laughed at all the mutes :D:D:D:D hahaha
Well worth the watch of this vid :D A few good laughs in this one.
I noticed the video didn't work to will being called remotely. The video was much smoother directly off the youtube site:
My whole car is shiny :). Actually, she's pretty filthy ATM. Needs a wash, stat!
Single pegger of doom. He should do powercruise :P
Man, that is FUNNY sh*t @ 10:00 - how fast does Noel fly past lol.
I reckon hey, it was as if I was standing still!
I was suprised I didn't have anything to say when the white 32 lost it. He was the lucky one I guess :P
Glad someone got some entertainment out of it at least :)
Interesting. I blame SAU :P
Mangs.
Tuesday is hectik like skidz.
Out.
well my days are not so hectik anymore lol.
Job hunting sucks azz
why cant i win gold lotto!
time out for me whilst chasing an electrical gremlin in a funky colored car..
(dan I think I worked it out.)
kiwi,
what happened?
kiwi,
what happened?
Had enough of getting treated like shit. plus im wanting to spend more time with kids.
it is dead quiet in the car sales game atm and when that happens it is always the sales peoples fault lol.
So if any of you good sau people know of any jobs going please let me know lol.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
