Who says you need a working car to go to ze german club? i had an epic half hour trek to get to it last time :nyaanyaa:
Anyway, why get a pair of SSD's? A single OCZ vertex3 and a motherboard with 6GBPs sata ports would be faster.
Agreed. Driving to the german club means less beer. And when you live as close a Geoff, public transport is easy.
One is fast, two in raid 0 is faster :).
I've been striping my OS drives for ages now.
:rofl:
+1
"I Piss Alone
I don't want nobody to know
That I haven't got the pressure of some of the other boys
They make a noise
That scares me so"
:worship: Regurgitator - Unit :worship:
Found my old CD collection, reliving the 90's every day in the car and lovin it...
I challenge you to get a copy of Unit and listen to it start to finish, good gear...
"I Piss Alone
They make a noise
That scares me so"
nice work. cant beat the '90 for good music :thumbsup:
Why do germans make such good food?? :cheers:
90's music is great, i wish i had been born a little earlier then i was so i could truely appreciate it though.
German food? I suppose it's just the basic food group of meat and awesome, plus the heavy beers mix so nice.
dont forget the salt that goes with that beer and meat....mmmmm, beer meat and salt
Last night, about halfway home, Mr Bent-Paperclip and I had a full and frank discussion with Mr ECU. rant.gif
Mr ECU has been saying nasty things like "MIL+SLIP!" but, frustratingly, always said "55" when questioned further. He's now admitted to 21. Blah.
That code only means that there is an issue somewhere with the Ignition Signal ( explanation of nissan error codes ) ... so could be coil packs, like I was suspecting, or other stuff (AFM?, a dodgy contact?).
I've got a family thing on tonight, that's why I can't make german club :(
    • Thanks, I'll shim that plug and hopefully it fixes it.  Yes still factory turbo for now, still have the misfire it's not as bad but still noticeable
    • I had someone check the CU, they said it was fine but it could be buggered  I was only running around 7-10 PSI on the dual stage controller, but my boost gauge is shit house and needs replacing so I'm not getting a true reading.  Then I ran from wastegate pressure as per Turbosmart but still have the same sort of issue
    • Yeah this is a thing. I've had mine setup like this for a few years now, works fine. If I dredge my memory bank, I think I had to do this after I removed my factory dash.  So you've tried it on gate pressure, I'm assuming this is the factory turbo? Did you still have misfire issues with that setup?
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
