Since when to the abc advertise their shows outside of the abc? They were advertising one of their drama show thingies with the other pre film ads at the cinema last night.
Sounds like it has something to do with timing belt/pulley area. mine has a sound like rubbing under 2000tpm from cam cover but it isnt rubbing. been there for 18months lol
So you reckon it could possibly be normal? I never noticed this sound before and in underground parking I can hear it a bit more clearly...
@sneaky pete:
You seem knowledgable on SSDs, school me. My knowledge is out of date.
My motherboard only supports SATA2 :(. Am I better off with:
A) 2 drives on the SATA2 ports in RAID0
B) A SATA3 PCIe card with a single big drive?
C) A SATA3 PCIe card with 2 smaller drives in RAID0?
I'm going to need at least '120GB', so a single 120 or two 60s are both options.
@sneaky pete:
I still go traditional methods.
I have a few clients who use SSD but found its really only useful on boot... And too many horror stories with RAID when one HDD kicks the bucket
define 'traditional methods' :P
HDD performance is definitely the most serious bottleneck on my system. Needs MOAR speed
I generally don't give a f*ck if my system raid dies, I just rebuild. No big deal.
I get the impression that for SSD's, running a RAID setup (the one that share the data, not the one that mirrors it across both drives) doesn't produce any noticeable gains due to the way the data is written to the drives themselves.
There's supposedly a decent difference with SATA2 vs SATA3 etc with the latest generation of drives
Unless your data isn't compressible (eg movies, or whatever your working with, you'll have to figure that bit out), devices that use the 'sandforce' drivers are supposed to be pretty darn good.
Choice depends on your budget though, but if you want what's considered by most to be the "best" consumer level SSD, the OCZ vertex 3 is probably it. PCI-e plug ins are about 50% more expensive, which is crazy.
Honestly, due to the fact yuo've still got a SATA2 motherboard, i'd just pick up a OCZ vertex 2 120gb (review. They might be 6 months outdated, but are still a great drive (blow away any disc based hard drive), wont bottleneck on your setup and are cheap, $190 from umart for a 120gb or $350 for 240GB
As far as usefulness of a SSD goes, depends on what your doing. I'm not going out of my way to get one (though 200 bucks for a 120gb one is cheap) because i rarely need the speed. other people might.
As far as reliability goes, your not realistically going to run out of cycles on the memory. Read an article on that point, and they pointed out that, though there might be a 10000 cycle limit, the fact that you aren't rewriting the entire drive every time you do something it would take about 10 years of normal usage to run out.
NFI sorry.
*snip*
Did some more research today, looks like you still see a fair bit of benefit with RAID0. I think I'll go with two vertex IIs in RAID0, might see if I can splurge for 2 x 120s...
Indeed *strokes beard*
Not sure if I can make it or not at this stage mang.
Let me know what time it is and I'll see what I can do.
sweet, will keep an eye on it
You guys play cricket? "the nets"
I'm a bit of an x cricketer... was thinking about getting into playing some warehouse or similar again...
we do, careful you might get a call up we are always short of people lol
Haha, I would love to play, but I haven't played a game for about... 8ish years... I actually come from quite a background of cricket until I took an injury which stopped me from walking for about 1 year and of course forced me to give it up
I imagine now I work on the PC 24/7 I'd be pretty unco - Although I still try to train quite a bit
Edited by wilorichie
from what i hear about the team you'd be a top rank player, smity can't bat can't bowl and can't field. Maybe i should even join your team? :nyaanyaa:
haha. Would love to go to the nets sometime with you guys.
I used to be opening batsman and had the odd over or two... But cant imagine being as flash as i used to be
Less cricket more Futsal.
there is a net session on sunday, I too used to be an opening batsman 12 years ago, its taking time but slowly getting back to form!
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
