As expected, didn't even hear them :(
A warranty claim just came over my desk though:
Complaint: Vehicle getting stuck in park
Cause: Buying an auto Wiring problem to shift lock release
Correction: Repaired wiring in circuit.
lolfarkin
Work over, and Marisa has just made plans with another friend of hers who is thinking of having a baby, so she's coming over to help with the babies and spend the night to see what night feeds are like
Boo Yaa, getting on it tonight
laps of happiness were good, plenty of open track :)
smity!!!! video!!:thumbsup:
Yeah, been playing cricket all day, will try and get something up tonight.
My CONSULT logger f**ked up so I'll only have GPS data to overlay :(
Did you like my demonstration of epic clutch slip as I went past you? It is completely gone - I couldn't get power down anywhere, in any gear, at any revs :(. Was pretty much limited to 20% throttle.
Had fun following you for a while though, and was still able to catch the pack when I opened up some clear air earlier on :)
New clutch time!
Not having much luck with wheels/tyres either. The front left on my track wheels is losing pressure again as well.
yeah i heard that, clutches often help :) was wondering what was going on there, and where you took off to in such a hurry. hope cricket was worth it, and look forward to seeing the vid.
Lots of happy happiness at happy laps. :thumbsup:
Was something wrong with the chair? Saw you going pretty slow and then you were off track early.
Found myself a busted rear main
Bummer :(
we lost but it was a decent game, didn't get our arses kicked.
I got a duck :(
Video sound is TERRIBLE :(. Stoopid gopro.
it was the one that got away
    • Yes. Get rid of that battery. It is dead. It will cause problems.
    • Don't assume too much when there is a voltage issue....if the battery is flat and the alternator not charging it is easy for the voltage to drop way low at the ECU due to the draw of stuff like coils, fuel pump etc Whatever you see at the battery with the motor off, it should be at least 13.8 with it running
    • I have been wondering if this is as simple as a voltage issue with the battery. Even on a charger, I can’t seem to get it over 11.8V on the terminals.    Unless the alternator has failed as well, that wouldn’t cause it to die in the middle of driving though.
    • I’ll give this a shot next time I’m able to wrench on it.    I was able to get my hands on a Haltech Nexus, so that should help with some of the more bizarre troubleshooting. Make sure the CAS is actually sending signal and will be able to set the proper dwell on the R35 coils.    I’ve checked power/grounds/signals at the CAS, ignitor, and plugs and it was all there. Granted this was static with ignition on, not cranking.    I also plan on swapping out the fuel filter and throwing on a fuel pressure gauge at the rail just to confirm I’m getting the correct pressure at the rail. 43psi if I recall correctly.
    • The attached document is fine. I just downloaded & opened it.
