To any one who has a white car...clay bar it. I didnt know my car could get THAT white!
True story. Best car cleaning product ever lol.
I was surprised at how little effort is required to get such a good result, defs the best, I am gonna give the poor little mazda a going over too!
must look at it. mine is a faded crusty white. if it will tidy that up then I will buy that product.
It's a prepping product before polishing. Gets all the shit that gets absorbed into the paint, tree sap, tar etc out. Clay, Polish and wax/sealer and you'll be good. or Clay and wax if your not too worried about swirl marks n shit.
I don't know if I'm goin to have time to get the car fully prepped for the SCC. Might only have time for a wash and a wax :( Been six months since she was clayed last and she is in dire need of a good polish.
to be honest my van will have a wash but it will still have a BIG ding in the side of it.
subaru will get a wash.
still undecided which one to drive. if I drive the subaru I will have trouble keeping my foot off the gas..
I would give it a go, It pulls so much crap out of the paint
clay bar is win. did mine shortly after buying the car. get rid of all that japan style smog thats been ground in over years. you should only do it every few years, as it will take off a layer of clear coat while its doing its thing, and make sure you keep it wet and very clean.....drop it on the ground and you can throw it away. strange considering it is from the ground.....:rolleyes:
might have to google this whole claybar thing
never used one, but hopefully will have time on sat to get the car up to reasonable shape for scc
Must be engine fire weekend or something
I have a bit of a problem with my taxi at the moment - we have pulled the gauges out of my car and one of them was an oil temp one, so I took the sandwich plate out (the one between the oil filter and the block) and fitted a new oil filter on. First of all it started leaking ALOT, tightened it up and it was fine. Went for a drive and it started driving like crap, got home and it had dropped the oil again.
I'm wondering if when they have fitted the oil temp sandwich plate in, have they removed something that was meant to be there before hand? Does anyone know if there's a stock plate that's meant to be sitting there? It's a Barra 182 from a XR6.
This afternoon I'm going to bang the old sandwich plate back on to get it going again, hopefully..... it works.
If the engine is blown I might as well pull it out and put a barra 240T in there, might buy a 32 pig or something if that happens.
Front yard mechanic pro tip: Check to see if the Oring comes off the old oil filter before you put the new one on.
In other news, there's further developments to having a 26 powered veehick-le in my g-raj .
Morning Mangs,
Long weekend was good. Back at work today is not so good :(.
Flying wedge is mobile again :D
Where are we meeting this week?
McFry!
What's the plan for SCC? Do you want me to meet you at your place? Or meet you at Hyperhole? If Hyperhole, I'll need a lift back in that direction afterwards :wub:
If you can get to my place at around 8:45 that'd be grand, because I won't have to take you home afterwards :). I probably have to do some work in the afternoon (from home) so if I only have to go home from lakeside (not via aspley) we'll be able to stay at SCC longer ;)
they take a lot of time and wear your arm out!
That's what she said.
Mangs is anyone keen for a car wash meet this week since BnR is out? Anyone know a self serve car wash that is fairly central?
    • Hi. This is just my curiosity because iam sure the tuner figure something out...but either way i want to ask. The "problem" is that the Nistune ECU (Stagea FW and RB25DET NEO from Stagea) sees many times the speed than the speedo does(he says the speedo show 120 km/h - correct speed and the ECU shows like 510km/h ) I told him that this car/tranny getting speed from rear diff. If iam not mistaken the RB25DET NEO "need" to see tranny speed sensor? (my tranny has the plug for it). So couple of "question" If he connects/wire the speed sensor to the tranny...are the signals gonna intervene and if...what if he disconnects the rear diff one and the speedo stops working? Or the "new" sensor from the tranny "take over" and will not going need the one from diff? As i said i know he figure/get that done...iam just curious to know what are the solutions 🙂
    • Your IACV is set to idle too low. You need to adjust it via the screw Duncan mentioned. From memory it should be 650rpm with the valve electrics unplugged. What is it trying to idle at with the IACV plugged in?
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
