TFIF indeed, I did not get the job I have been acting in for the best part of a year, need to get blind, This is what happens when the selection process is being run by other units and not your own.
What role was it? I heard a bunch of contractors applied for this Acc Payable role, and none of them got it. Even though they'd been doing the job for some 6+ months.
I also, applied for a job today. Me and someone else and the selection team are all recommending me.
I also just found out that In Flames, Lamb of God and The Black Dahlia Murder will be playing at Eatons Hill Hotel in Feb!
Edited by hylian
bummer dude :( sorry to hear that
I was a bit pissed when I first found out...but then I realised that in 10 months time I will be able to apply to 'progess' my role into that same payscale anyway so at worst I have only been set back 10 months. And in talking to my boss I dont think he is going to fill the vacancies in our team from that order of merit anyway as he doesnt like the order so he may be running his own process for our team soon.
6/64 now. I should have f*cking taped it, the game will be over before I get home tonight at this rate...
They really have no business in international cricket
Principal Environmental Officer in DERM
Rain delayed again... Bloody rain. At least it will save us a bit of embarrassment. 1/7 currently.
I dont think we will have much to be embaressed about in a few sessions time when we have an epic lead!
f**k the weather.
f**k Phil Hughes is a useless prick. Lucky we dropped Catto, he would never have been able to match P.H.'s amazing feats of getting out the same way three times in a row for f*ck all...
@Carl: Yes, suit up :thumbsup:
I've called and check if the Go Kart is available next Saturday and the reply was only at 1pm. Anyone keen or should we try next year?
I wont be able to do 1pm. Up to you guys though.
I'm easy either way. Next year will probably be easier to organise. Any expiry date on the coupons?
1st of March... That gives us 8 weekends next year.
Smity,
Some dudes wearing white will stand around and chase a small red ball while the commentators discuss banalities like the number of seagulls that were on the field when Australia played England in 1988 and how that compares to today's game.
I actually like cricket but this test is a bit of a farce from both sides.
This test is going to be awesome, chasing a gettable total on a difficult deck, what more could you ask for as a finish to a test?
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
    • Unfortunately the cavaet to that is that while any scan tool should be able to read the code, the workshop will need a consult plug to OBD socket adapter. You don't have a location on your profile, where are you based?
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
