>butts in....
For those attenting happy laps @ QR with SAuQLD on 15th Jan please note the new on-track time of 6:30am. Pass it on folks.
successful day was successful. got the last 3 cartons of spaten oktoberfest from the german club, and mowed the lawn like a baws with newly restored ride on. Win.
Next job: Fit turbo to ride on :thumbsup:
f**ker
was planning on going out there tomorrow to get one more carton
Somehow landed a gig of designing and testing the infrastructure to be put on this new mine site.
Watch this space for epic failures.
Nice Mang. Who is that with?
Anyone play BF3 on PC? Need someone to do co-op missions with...
Yerp can probably do some co op. I normally just play bulk conquest though lol.
Still with the same company, we have a contract for a mining company (largest in the world, to give you an idea) basically I am currently moving in and out of asset groups as IM from each of these groups keeps wanting me to stay with them so I move around so they don't get attached to me. This new project is a bit daunting considering I've never done anything like this before, I will have network services at my disposal as well as countless other pros just around the corner so if successful will definitely look good on the resume.
I expect this site to go into full execution end of this year. So if I'm hanging from a light fixture, you know why.
Morning Mangs,
Back at work :(. FML.
Great Stuff Keaton!
Yeah you unlock sh*t from doing co-op though :).
Add me on origin: Smity42. Then we can do co-op, and multiplayer on the same server, etc.
Going to umart this arvo to get a new video card and some SSDs... PC was struggling with this new fangled BF3 shiz...
I thought that was about regular HDD's or something...
Still, graph
That being said most of the 240gb drives are more than double the price of a 120gb drive, so its a non choice anyway
why run just standard drive setup.
I bought bf3 on the ps3 cause i wanted to play it without having to upgrade my computer just yet, now my computer is starting to die looks like i'll have to upgrade anyway
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
