I've been bludging for 7 weeks now :P
I'm right there with you... Savings are no more though :/
Meet on tonight? Need to get paintball deposits for those that are going.
Quick advice time. I currently have a company car with a $250 a month fuel allowsnce whi ch i pay $55 + $6 insurance reduction per week. I can get a car allowance of $150 per week ( so i dont have to pay fbt) i own my car outright. Should i do it? It does mean turning the skyline into a daily but i think it is worth it. Whats everybodies thoughts? Cheerz
My bet would be on no, not worth it. Extra maintenance and depreciation would probably be the killer. Don't forget the hike to your insurance as you are now using your car for business purposes. It would need an accountant to go over it to make sure however. if the $150 a week you would get would cover ALL of your maintenance, fuel, extra insurance and depreciation it would be worth it but I doubt that would happen.
Please note that this does not constitute real financial advise. Go talk to an accountant :P
I only need to drive it to and from work. Once im at work i use any car i want. im worried bout the extra maintance as well.
I use my skyline as a daily, although I have very short trips to work so I don't mind. I just love the feeling of getting into my car after finishing work each day. To each their own though :)
+1
exactly the same... i live 5mins from my work.
ive had my daily for 70,000kms and it still goes like a shower of shit :D
this man knows where its at. my skyline is my quiet comfy A/Ced daily driver....thats what i bought it for.....>_<
My drive to work tho is at least an hour( warner to morooka) i love driving it, will my love go away when im driving it? Thats my biggest concern coz that would suck.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
    • Could be correct. Meter might be that far out. Compare against a known 5 ohm 1% resistor.
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap.  (edit: I went out and did it right now, the line I had chosen did appear to have no vacuum on it, it used to go to the front of the intake, I've now completely blocked that one off at the bracket that holds several vacuum lines by the firewall.  I T'd into the vacuum line that goes from that bracket to the vacuum pump at the front of the car, but no change in the MAP readings).  Using the new vacuum line that has obvious vacuum on the hose, im still only getting readings between -6.0 and -5.2.  I'm wondering why the ECU was detecting -5.3 when nothing was connected to the MAP nipple and ECU MAP selected as the source. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
