f**king housemate hasn't paid the bills AGAIN! Was thinking about moving out late March to early April when the lease was up, going to be a definite now. Try find something cheaper than the $260 a week I currently pay.
been there... done that... he no longer lives wih me. last i knew he was sleeping on the floor of someone elses house
Scrackin mangs?
So a month after the turbo install started it is finally finished, on my end anyway. Fitted the injectors and fuel pump today and did an oil change and flushed the radiator.
Only problem we had was one of the RB20 AFMs that I've got is a dud so it was being a prick at first wouldn't come on boost while driving just got fuel cut as soon as positive pressure was reached. So swapped it all out for the stock AFMs and it works fine now. I'm just going to get it tuned with the stock AFMs for now, can't be f**ked anymore I want the care back on the road lol.
Today = great success.
For the mangs who aren't on the 31 club. We got some new wheels for the ute.
Edited by Beelzebub89
Are you trying to make the ute the ugliest thing ever? Hellaflush fitment (or whatever the hell you want to call it) is just bad!
It's an R31 Ute...it will never be pretty. Front has a little too much poke atm but once the motor is in the guards will get some hammer love and all will be well.
lol looks very mad max
:thumbsup:
I like it, needs to be looking dirty boz
This man...he knows.
If its the one you got off me you're welcome to your money back :P
Whatchu talking about? She's gorgeous.
It's sport that isn't tennis so I'm keen. My housemate has been hogging the TV to watch more or less every game of the Australian open. Couldn't think of anything more dull to watch than tennis...
    • Hi. This is just my curiosity because iam sure the tuner figure something out...but either way i want to ask. The "problem" is that the Nistune ECU (Stagea FW and RB25DET NEO from Stagea) sees many times the speed than the speedo does(he says the speedo show 120 km/h - correct speed and the ECU shows like 510km/h ) I told him that this car/tranny getting speed from rear diff. If iam not mistaken the RB25DET NEO "need" to see tranny speed sensor? (my tranny has the plug for it). So couple of "question" If he connects/wire the speed sensor to the tranny...are the signals gonna intervene and if...what if he disconnects the rear diff one and the speedo stops working? Or the "new" sensor from the tranny "take over" and will not going need the one from diff? As i said i know he figure/get that done...iam just curious to know what are the solutions 🙂
    • Your IACV is set to idle too low. You need to adjust it via the screw Duncan mentioned. From memory it should be 650rpm with the valve electrics unplugged. What is it trying to idle at with the IACV plugged in?
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
