Any sport that calls itself "Football" and has even less use of the feet than rugby/league has got to be a joke
This is why we cant have nice things.
On the topic of superbowl, I am a Giants fan, I am excite, I want to see the winning touchdown in the final seconds again, also DIAF Tom Brady.
I plan on eating nachos and drinking beer. Then I'll probably have a nap. Should be a good day :)
I will likely be at work, but there is a guy here who usually sneaks out to watch it, I will probably follow him.
Yeah. I was speaking to a guy who went and did it a few years ago, all i remember him mentioning is that there was way to much mud.
I like golf...
Do you like watching it on TV though?
Quiet you.
Martin having a look at tickets for Spa in September if you're still keen
Spa
Still keen, send me your itenerary so I can work out whats worth flying over for
Pretty cheap to get in standing. Just hope like hell it doesn't rain.
F*ck standing. Grandstand is where it's at.
Its Spa....definitely going to rain lol. 3 day Gold pass on Eau Rouge is only $550 or something like that.
Nice
We still on for buranda tomorrow night?
The office I am currently working at is about 5min from there... which will leave me in a dilemma - do I stay at work till 7:30 or.drive all the way home and then all the way back?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
