agreed...not taht i have that issue with meets....just everywhere i drive for no reason at all...i swear my car has a Police GPS tracker in it.....
whereas...i drove my old Beetle home the other day. i forgot how overly loud that thing is (104db at idle)......and yet it go no attention from the cops. and twas my daily driver for about 7 yrs.
I was arguing this over in the wasteland. The police don't really have much choice. For every sensible driver with a legally modded import there are 10 douchebags driving like idiots in unsafe an illegaly modded cars. There are no doubt more shitbox falcadores and econoboxes but they don't stand out. Cars that stand out + large majority being driven poorly/illegally modded = police attention. Not much we can do about it :(
yup thats the main problem.
and i guess the beauty of old cars is that most cops dont know what theyre looking for or at...so they just let it go.
to a point. once they mark a car you are pretty much screwed. the subaru attracts no attention but at the same point I am not looking to attract it either.
part of the reason I now stay away from the JDM meets out at QR. those are going to end in tears for a lot of people if they get any bigger.
this
that is true.
and the only place i ever got in trouble in the bug was playing silly buggers up the main police patrolled drag up here on a thursday night.....so it was bound to happen and i was young and stupid
by old car i mean pre '80's btw. most interpretations of old car is a early to mid '90's como :)
very true. but compared to what i know as old cars. even an R32 is quite refined
this
my 74 bug and my 89 skyline seem like they're from different centuries in some ways. And 20 years old is NOT OLD.
And that was $60,000 in the early 1990's for some of those cars, probably worth a hell of a lot now (inflation an all that.)
You just have to look at some of the features on the cars to see how ahead of the curve they were. Digital dashes, in car Nav/DVD/TV, HUD's, Automatic climate controll and so on. Then there is the mechanical side of it as well, look at how quick the 33 GT-R was around the ring.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
