Mangs,
Yeah the reality is that while as the crow flys it's not much further than ikes cream for me, it is much more of a mission to get to :(
Keen for somewhere closer to indro/chappel hill/toowong/taringa etc region (or even further north :))
Have to ask Col, why lock that SPAM topic and not just delete it?
lol I also thought that...
But... bit of a down note, I just took a deposit for my car :(
They are flying in on the 3rd to complete the sale and pick up the car... I actually feel sad typing this :(
if you went somewhere that sold ribs/steak instead of ice cream you will attract a fatter crowd
Did you say rib's? I'm in.
hells yeah... ill call petrie tomorrow and see if they have enough... :P
We can hook up a date and see if they will do the unlimited rack deal again for us...
